Multi Top Box Lock Removal
Discussion in 'Technical Help' started by BigAlan, May 5, 2021.
  1. Before I go and break anything does anybody know how to get the lock out of the standard Ducati Top Box?
    I think I have sold the bike so I will give the lock to the new owner.
    Thanks
    Alan
  2. if you look inside the box behind where the lock is, there at least 2 very small screws, remove them & the lock cover comes away, if I remember correctly the barrel is held in place by a large nut & when undone you pinch the 2 lower tabs on the bottom of the lock barrel & it should slide out of the lock “tube”
