1200 DVT Multimedia System.. What Did It Actually Do!
Discussion in 'Multistrada' started by madasadad, Jun 29, 2018.
  1. So I’ve connected my phone to the Mutlimedia system and it shows a phone number when I’ve an incoming call to my Bluetooth headset that is connected to both my phone and my sat nav and my partners headset. So am I missing something, or is displaying a phone number all it does?
  2. You are allowing ducati to know all of your contacts & share that information with other companies. Nice little perk for them,..but you can see lean angle with some app'
  3. You can skip music tracks and it will display the title of the track, also a little bubble will appear if you get a text message, and if you are really lucky it may adjust your volume but that hardly ever works.in general I ran it for a while but it actually stops the Sena,s I use from using their full capabilities so now I unpaired everything and don’t use the bikes bluetooth
  4. After 2 years with the multi, I do not remember the multimedia, when I changed the schuberth C3 with src pro, to the C4 with the advanced of sena, I stopped working on the volume of the music, which was what I used most, and also , I could never handle the intercom itself, to connect with colleagues, so a while ago, buy the hands-free model of RC4 and the truth is that I find it much more useful. The multistrated application, I do not use it, I do not care how many degrees I lean, nor how many CV I use, so I have not reopened the application
  5. Tried to use it. Was very inconsistent and if it had the player on it seemed to not then be able to change the display mode until ignition off. So not bothered since.
    Only use for occasional times I use the app
