Hi all, I am having the opposite of what every Multistrada owner has in the rear brake not working, well mine is seizing on!!!!! I have adjusted the rear brake lever correctly and even backed it off more than it should and got less fluid than it should have but still seizes on, I have noticed my ABS light comes on and the DTC switches off on its own, I don't know if this is causing the seizing on or the seizing on is causing the ABS, DTC to switch off. Any ideas will be greatfully appreciated
