1200 Mutley 1200 10-14 Right Hand Guard
Discussion in 'Multistrada' started by Shoboshi, Sep 10, 2017.
  1. Hi Guys...
    As per the thread heading, I am in need of the Right side hand guard (Throttle)
    Damaged (snapped!) by a whacked football. Hard to believe but true.
    If you have one spare in exchange for some beer tokens let me know via pm.
    Cheers.!
    Norm
  2. I repaired mine with super-glue as a temporary fix. You could always get some salvaged plastic bumper/trim & make up a splint & drill some small nuts-n-bolts if its a massive crack. If you want to get bling try out Ilmberger Carbon.
  3. I had to replace one a couple of years back (not including the indicator)and a new one wasn't expensive.
  4. Totally snapped it.!
    Couldn't believe it when I saw it. Carbon could be the way to go.
    I'll have a go at the temp repair in the meantime.
    Cheers Gunz.!!
    Norm
  5. I decided to upgrade to carbon & then added ducabike guards (through conquestcarbon in traders section) which also add a bit of weight. Meaning slightly less vibes on the mirror at reasonable speeds. Barkbusters do a metal protector also.
    You can get a 20% reduction on parts from conquestcarbon if you ask for a discount code on here. And the ducabike parts are in the 'cnc' section & might be only 10% discount but still not bad!
