899 Neutral Light.
Discussion in 'Panigale' started by Nelson, Dec 2, 2017.
  1. Hello Pani people :)
    I understand the neutral light (or lack of) is a common problem on these bikes.
    Is it simply a case of fitting a new sensor?
    Cheers
  2. You can first try having it recalibrated, or put thru the learning procedure again. Dealer job though. A new one needs to go thru the same procedure but I've saved a few by doing the former rather than fitting a new sensor from the off
  3. Thanks Nelly,
    Mine stats to work when the bike warms up, again appears not to be uncommon.
    'Character' :D
  4. Mine just went through this process today. Pretty straightforward job it would show the bike to be in first, despite being in neutral. All fixed now.
  5. Mines ok today whilst sat in the garage...Must be the balmy temps we're having...:cool:
