1098 New Brake Discs
Discussion in '848 / 1098 / 1198' started by NoGutsNoGlory, May 2, 2017.
  1. EBC have been around for a long time. I prefer Brembo HPKs or Series Oro if you want floaters. Similar in price to what Demon Tweeks want for the EBCs. £542 for a pair seems a little on the expensive side. Andy
  2. Thanks Andy I must read the full ad I thought that was for a pair!
    HPK's are cheaper from the states I might go for them instead.
  3. Had HPK's on my 999s, Luved them, Imo wavey disk's look cheap/ wrong and on the 2 occasions ive had bikes with them I hated the feed back to the lever.
  4. Not heard anything good about waveys on Ducati tbh. Fitted several sets of Serie Oro and they are great. Good value to. The HPK's are very good. Both are floaters. Bear in mind stock are 330mm and many aftermarket are 320mm diameter. You can remove the spacers on the calipers for them to fit up correctly but you may need to use the slightly shorter 848 caliper bolts.
  5. Thanks Neil I'll have a look now. I would rather fit 330mm as don't want to be messing about when changing wheels.
    BTW the K-tech forks were awesome thanks again.
