New Exhaust = Change Ecu?
Discussion in 'Technical Help' started by RoadRunner, Feb 3, 2020.
  1. Hi, if I replace standard end cans with Termignonis do I need to upgrade/flash the ECU and/or change anything else? Also, is the change worth the cost apart from the look? RR.
  2. Thanks Sev, not so concerned with HP figures (fast enough as it is, for now); just wanted to ensure if I swop the end cans over on my 848 I won't destroy the engine in an instance. Sounds like I can swop and then get a dyno/ECU map later without issues?
  3. you need to dyno it to see it is running across the rev range at a variety of loads at the correct fuel to air mix, ie won't blow up. the fact more power generally comes from this is a bonus.
    im sure you'll be fine for a while but the point is you'll never know its wrong until you look or it blows up!
  4. Ummm.... I may well leave it for the time being then. I won't be riding it flat out that's for sure so won't need the extra HP (just yet) and Bristol is a long to go for a dyno. Will ponder this one - but really appreciate the quick and comprehensive (tech) advice from you guys. What a great forum!!
