New Member Needs Help
Discussion in 'Newbies Hangout' started by Mark Fogarty, Jul 14, 2019.
  1. I've just bought a 2015 Multistrada 1200s, when I put in the centre stand I noticed front lower engine/frame bolt had a nut missing, to resolve I've fitted Evotech crash protector(Bobbins), could some one help with the torch setting or direct me to a Haynes type work shop manual for info.
    Cheers
  2. Aren't you in America promoting that new motorcycle of yours;)
  3. Welcome to the Ducati forum
  4. Cheers
  5. I'm afraid not!!
  6. Welcome :):upyeah:
  7. #9 noobie, Jul 14, 2019
  8. Welcome Mark from Brum, iirc engine mounting bolts are 40-45nm
  9. This is from r&g on their Q&A
    R&G do not provide these as the use of compression sleeves inside the bobbins enables adequate tightening of the bolts and the bolts will stay secure. For peace of mind use some Loctite or similar. Do not put bodyweight behind tightening as this can damage the bolt and even strip threads in your engine, leading to expensive repair work. In any situation DO NOT exceed 40 Nm of torque. For engine bolts, please consult the owner’s manual as they generally detail torque settings for your machine. You can use the following as a general guide for different bolt sizes.
    general torque settings
    M4 BOLT = 8Nm
    M5 BOLT = 12Nm
    M6 BOLT = 15Nm
    M8 BOLT = 20Nm
    M10 BOLT = 40Nm
  10. welcome mark'
  11. Cheers
  12. Thanks for the info it’s going into Ducati Coventry Tuesday
  13. Thanks for your help
  14. Cheers
  15. Welcome and enjoy
  16. Hi Mark and welcome to the forum. :)
  17. Cheers
  18. Cheers
