Got a bunch of new stock that I will be adding to the store soon. A few specials and carbon parts too. If you need the odd bolt or spacer, clip, rubber nut, cable, axle, bar grips, instrument housings, with parts fitting a wide variety of models then check out the following link. I have amassed a lot of eccentric Ducati parts over the years and some are simply ridiculously expensive from a dealer or are extremely hard to find, so maybe I can help, if you are undertaking a rebuild or restoration, or if you need that elusive component. Ricambi Moto
I've a lot of take off parts from a Monster 620ie going on the site in the next week or so, which are now surplus to requirements following the rebuild I recently completed. Most if not all are as good as new, including the original clock surrounds/binnacle, which if your originals are broken, is a very cheap way to revive them without forking out for an eye-wateringly expensive new set from your dealer, as you have to buy the entire instrument cluster. You can simply replace the internals into the housing and you are good to go. I also have a load of CNC racing billet alloy parts that I want shot of, so keep checking on the site. I will try to upload them as soon as I can. Just sold a fuel connector for a 999 to a chap in Holland, as they are notorious for the O-rings hardening or tearing allowing fuel to leak. £12.00 from a dealer ordinarily!
