Newbie From Cumbria
Discussion in 'Newbies Hangout' started by Johnwb, May 17, 2022.
  1. 2014 1200 with SP engineering slip on. Exhaust. Sounds awesome
    Owned since sept 2021. Has an intermittent starting problem. Any ideas anyone?
  2. Welcome to the forum.:)
  3. Welcome. Describe the intermittent starting problems, sounds etc. someone will be along I’m sure!
  4. Greetings!
  5. welcome johnwb'
  6. Welcome along
  7. Welcome and enjoy
  8. giant-axe-in-car-prank.jpg Welcome.:upyeah:
  9. You’ve had your Dinkies out in public again!
    The nice men in the white coats will be along shortly:)
  10. Not for two odd weeks as they're away playing golf in Turkey.:)
  11. Thank you for the welcome.
    problem
    Key turned on, dash goes on, you can hear the fuel pump work.
    Press starter key, dash goes off and engine doesn’t start.
    been in at garage. They checked codes for exhaust and kick stand. Got it going again. Picked it up last Saturday. Slow through Carlisle, then just as I increased the revels at the bypass, the exhaust popped open at the spring joints. Got home. Then it wouldn’t start again. So now back in garage.
    any ideas?
