Have a Biketek 1/4 turn keyless fuel cap on my trackbike and the o ring is duff Does anyone know eher you can get large diameter o rings ?
Simply Bearings Ltd ~ Oil Seals SKF FAG TIMKEN KOYO NTN NKE TRULOC Needle Rollers Taper Rollers Rod Ends Oil Filled Bushes Loose Balls O Rings Grease Plain Thrust
give spen bearings a call. they'll sort you out and they're just down the road. moor bottom, cleckheaton.
Doesn't an o ring that comes in contact with fuel have to be made of Nitrile rubber? because ordinary rubber will degrade if left in constant contact. I'm pretty sure because I had to get O E Nitrile for the fuel tap on my Honda XR400R
Correct me if I'm wrong, but isn't Viton the stuff which is made mainly of fluorine? And which if overheated decomposes into hydrogen fluoride, which is very nasty stuff indeed?
There is certainly high percentage of fluorine in Viton and it my well degrade into HF (can't say I've seen a reference to this) and of course aqueous HF is particularly aggressive. However nitrile is generally rated to 120°C and Viton to 200°C Bare in mind the OP was talking about a filler cap. If your worried about about Viton best remove the OEM seals from your bike sharpish
