999 Ohlins Fork Cap Tool
Discussion in '749 / 999' started by TheJackal, Sep 25, 2020.
  1. Make sure you crack the cap off before removing forks from bike.
    Which I am sure you know :upyeah:
  2. make sure you undo the top yoke clamp before you try to crack the cap off.......
  3. No worries guys, I've done this before!
    Just wondering if this is the correct tool in terms of OEM equivalency.
  4. make sure you put the bike on a stand before you remove the forks!
  5. Make sure forks are fitted to bike before removing said forks, otherwise you will not be able to remove them as they will not be present on the bike.
