Would anyone know the correct air gap for the Ohlins forks? After suffering a weeping oil seal over the winter I need to top up the nearside fork so instead of draining and re-filling I plan on topping up to the correct level with 10 wt oil. I've tried a few online resources without any luck. Thanks in advance.
I'm not sure but I think some air gaps are measured with the spring removed...I know it doesn't help but something else to be aware off.
only Öhlinsoil 1309-01, after filling, push the Damperrod down to drain the Oil Oillevel without Spring and -spacer is 170mm Aircolumn, is 706 cm3 Oil
