I have just fitted an Ohlins rear shock to my 749s. This is what is written on the spring: 1091 21/75 My weight is aprox' 75kg. Is this the correct spring for my weight?
That would depend on what your doing with it? Set the sag / preload and put a cable tie around the damper shaft to measure maximum suspension deflection. Then go from there. I'll have a double check at what's under the back of mine. I wouldn't like to commit but I'm. Sure it's a 90nm. /
Yes, the spring is a 160mm long spring. Rated at 75 NM. Perfect for your weight john. Will be too light for a pillion though
Thanks for the chart Ducati2242. I presume that rider weight is what the rider weights when kitted up with leathers and helmet etc? Looks like the 9 is good for me. Won't be carrying any pillions on my monoposto
