Oil Change Parts ( Testastretta Engines )
Discussion in 'Technical Help' started by DarR, May 17, 2021.
  1. This is what you will need for a complete oil change on a Testastretta engines found in Multis, Monsters, Diavels etc. This assumes you are replacing all o-rings and gaskets some of which you may re-use.
    • Shell Advance Ultra 4T 15w-50 Performance Synthetic Bike Engine Oil - 4 Litre
    • Oil filters 44440038a
    • Crush washers 85250421A COPPER GASKET 12.2X18X1.5 MM
    • Small oil ring mesh filter 88640331A O-RING 17.96X2.62
    • Large O ring mesh filter 88641581A O-RING
    • Three bond 1215- Sealing compound or Permatex 82194 (also known as #599) Ultra Grey Rigid High-Torque RTV Silicone Gasket Maker
  2. You've forgot the digestives and mug of tea.:upyeah:
