Oil cooler hose 'O' rings...
Discussion in 'Technical Help' started by Dukedesmo, Aug 22, 2013.
  1. Fitted a second oil cooler to the Monster today to try and keep the heat managed better, had to improvise for the hoses as I didn't have one of the correct length to link the coolers but got it working fine with an extra long hose (coiled around the intake) so will need to source something better soon, but in the meantime I could do with some replacement 'O' rings for the hose fittings (2 per end).
    They measure (approx.) 8mm internal, 10mm external and 1mm thick and are green (presumably Viton?), not sure if Ducati sell them but does anyone know the exact reference/size etc. so that I can order some from an 'O' ring supplier?
