Hi all! The last couple of rides i have noticed that a have oil leakage at the carter ventilation and i see oil leakage below the airbox, i think both leakage are linked together but what could it be?? Could the Carter ventilation be the problem that it is broken inside? As well yesterday i had suddenly Some problems with the gears. It couldn’t change to the first/ second gear and when i had my clutch in at a traffic light the bike still wants to move on???? Thanks for the big help!
I don’t think that wasn’t the problem i have bleed the system 4 times but it keeps coming back, so i have Made a appointment with the dealer because i have the oil leakage aswell
Hi, how much oil leakage? I believe when you say “Carter” you mean crankcase/engine case? Where is the leak located?
It is indeed the crankcase breather. The pil comes from below the carbon airbox on the engine and from the crankcase breather
