1200 DVT Oil Line Wear
Discussion in 'Multistrada' started by Dorsetdave, Jun 1, 2018.
  1. Not sure if I have the only problem with my oil lines. Just fitted Altrider engine bars and after removing the plastics and fitting the bracket to the left hand side radiator mount I noticed the heatshrink tubing that covers the braided oil lines had completely worn through and the braid was showing. It had been rubbing on the rear edge of the coolant radiator so I cable tied some plastic over the pipes to help and hopefully it will protect from an oil line leak.
