For Sale Pair Heated Grips For 1200 Multistrada 2010-2014
Discussion in 'Parts, Accessories & Clothing For Sale' started by DucatiChappie, Feb 5, 2022.
  1. Hi
    Having a clear out and I have a pair of used heated grips for a 1200 Multistrada 2010-14. This is the inner body with elements and wiring harness only, not the rubber outer grips (you can re-use your exiting grips if you remove them carefully).
    £60 the pair plus postage.
    Message me if any questions.
    Thanks
    James
    #1 DucatiChappie, Feb 5, 2022
  2. Hiya chappie.
    Could you send me a couple of photos of the grips please, are they a standard plug in system with the Ducati sockets ?. Dealership to activate.
    Kind regards.Peter
  3. @DucatiChappie
  4. Hi Pete
    Yes, these are genuine Ducati and use the same connectors (JST).
    I believe that if heated grips weren’t fitted from the factory then you’d need to get them activated by a dealer.
    Photos attached.
    Cheers
    James
  5. PS, I’m assuming that the female connectors are already present on your bike? Unfortunately, it’s a tank off job to see!
