Long shot... I have a spare pair of light wheels from my 1199. What are the chances that the front at least might fit my 796?!?
If you have them already, why not just try them? Rear no chance but front may...likely disc offset would be the problem
id say the front will fit but you'll need to use the original spacers and probably discs unless the offset are the same..panigalw wheels fit on to a 1198 with said adjustment
I have very little spare time, but would obviously try it if there wasn't a clear consensus here. The rear spindle is definitely bigger, but I thought the front might be the same. Given the uncertainty, I will indeed investigate myself and will report back in case that assists anyone else.
