It is with an extremely heavy heart I do this but my 1199s is up for sale. 2013 1199s registered on 19/08/2013 so a very late 13 plate, should have probably waited 10 days but there it is. It's done to date 7648 miles, although this may creep up as I probably need to torture myself with a couple more days out on it before it heads off. Ohlins all round and Marchesini wheels as per the S model. Regularly serviced and cleaned/washed/chain oiled/checked over. The bike has seen very little rain (except when caught out and thats only very small showers) and has spent winters tucked up out of all the associated rubbish. It has done trackdays, probably 10 in total and mostly in 2014 when life was being kinder to me and the oil and filter was changed pretty regularly (every 2 or 3 trackdays). All the funky bits (rear sets, carbon fibre, etc) shown in the pictures are being taken off and the bike returned to standard and it will be serviced with an oil and filter change at JHP. The bike is being collected from JHP on the 18th June after the work is done. It will also come with a carbon fibre number plate holder as I seem to have misplaced the orignal plastic version unfortunately (looks very similar though, just in cf) and I will probably leave the tracker on it as it isn't going to be much use for a couple of years. Bad bits: It has a small knick/rub in the swing arm where a bolt holding the gear lever came undone. A knick in the rear wheel which I suspect is something flicking up and catching it The tank is red and not painted up with the Alstare scheme. Scuff on the left bar end, mirror case and on the wheel nut (last 2 points are where it fell off it's stand and the clip on, lever and tank were replaced). There are also a few stone chips and small scuffs that have come from use. Bike is based in the Swindon area and looking for £13,500 Matt P.S If you require any additional info/pics let me know and I will be happy to provide.
