Panigale Coolant Level - Track
Discussion in 'Technical Help' started by Expat Jack, May 24, 2023.
  1. Need to top up the coolant on my V2 track bike.
    What is the wisdom re fluid level? Bottom line (like Triumph Daytona’s), top line or middle for diddle?
    Asking as some bikes are quite sensitive to levels and I don’t want to chuck coolant out the bike (or boil it over).
    Thanks all.
  2. When my mate had his Tri-Options bike they were all running them on the minimum line, same with the oil as they had a tendency to expand a fair bit otherwise when running really hot. You are totally correct re the Daytona's, those things you can really only run them on the min line or they chuck it out.
  3. Oil lower line for sure. I checked this personally with Moto Rapido.
