I bought a new front stand from Demon Tweeks for under £55; including extra pin to fit under bottom yoke. Pin out of stock till mid November mind.
I have one with various fittings, you're welcome to try it so you dont get the wrong pin. Likely the £55 one is similar
27mm pin was the Pani one I ordered as the pack of pins you get with the stand are all too small. At least this is what their site said!
Hence I suggest he tries mine. I have a couple of bigger pins but think they will still be too small.
I just bought a headstock one for my track bike but it won't for with the fairing on as it pushes on the underside of the plastic.
Ideally I'd want one that fits under the forks but not really fussed as long as it don't mark the body work.
I had a look at mine this am. Agree with Creamy. I can’t see how the pin can locate without much faffage. Have you got an ABBA stand with front lift arm, highly recommended.
I have one of those too grab them and take them both. The ones under the forks are ok for warmers and storage and wheel changes with some practice.
Might aswell order a set of gavin at gee-tech seens as tho ya probly won't need um for a few months unless ya doing euros
