Photobucket Fix
Discussion in 'Lounge' started by Mr C, Jan 26, 2018.
  1. Try this if you use Google Chrome and you should be able to view all those photobucket links that are currently broken.
    "If you're using Google Chrome, go to the three dots on the top right side of the screen and click them. A drop down should appear. Hover your mouse over "More Tools," and when the next drop down appears, click on extensions. Go to the link towards the bottom that says "Get more extensions." In the search box, type "Photobucket Fix," and hit enter. Click the install button and once it's done, you should be able to see photobucket pictures again"
  2. There is also one for Firefox named Phoobucket Hotlink. This needs to be added as an extension. (1.3.14)
