easy guys. I recently purchased the conquest carbon version of the PP screen. I wonder is there a difference in mounting hardware for the actual PP screen. As the rubber mounts and sleeved screws are to long from the original screen of my 2014 MTS. Just need to know as I will order the PP mounting hardware or some washers. Regards, Josh
Yes, they use a different sized bolt with a built in washer (on the genuine Ducati version) and they don't use the rubber mounts (I used some rubber washers just to prevent vibration)
Thanks mate appreciate that, any ideas where I could order the hardware from? Try to avoid dealer prices if possible.
I can't remember exactly which size they take, I'd bought the genuine screen from Ducati and it came with bolts, but these are the type you need with a button head. http://www.ebay.co.uk/itm/M3-M4-M5-...SCREWS-/321232365051?var=&hash=item4acaf0e5fb These are the washers I bought http://www.ebay.co.uk/itm/50-x-FORM...-M8-M10-KIT-/201436757286?hash=item2ee690fd26 The thread width is the same as the ones you take off.
