Proud New Owner Cagiva Elefant.runs Okish But Lacks Enypower
Discussion in 'Other Bikes' started by russ ele, Jan 29, 2019.
  1. done new plugs clean carbs balance carbs clean air filter all runs a bit better but still holds back.any help....
    russ
  2. Have you checked all carb hoses for any splits?
  3. What about any other Irish power rock bands?
  4. breather pipes good?
  5. pipes all good
  6. Is it firing on both cylinders?
  7. what Were the float heights set at?
    #7 Mark9, Jan 29, 2019
  8. work on her to day let you know how i get on thanks for in put
  9. Thread moved
  10. all pipes good fule pump good ,compression good ,bike still same,try some eles tomorrow,at least i know what its not
  11. are the carbs the CV type? diaphragms ok?. does it have an accelerator pump on the carbs? cant mind the proper name for it, carbs, so old hat.. but it should fire in an extra squirt of fuel when you work the throttle.
  12. diaphragms all good done eveything for fueling,so tomorrow its new ht leads and caps, then its coils......we see
