Im considering putting radial master cylinders on both brake and clutch on my 998. Question is, have any of you fitted them as I’m a little concerned about clearance as there doesn’t look much room when turning the bars! Also, if I do fit a radial clutch, will my choke just spin around as I notice the std bar clamp has a notch for the choke to sit in? Any advice would be appreciated
