Re-Boring Cylinders
Discussion in 'Technical Help' started by Pablo Pirate, Aug 3, 2013.
  1. Howdo!
    Can anyone recommend a company for re-Boring a set of barrels?
    Cheers Pablo
  2. I think DesmoDuke had some done the most recently - last couple of years or so.
    Yes - that one! "I've used Langcourt a couple of times, quick turn around and quality was spot-on."
    (DukeDesmo)
    #2 Chris, Aug 3, 2013
  3. You don't say what sort of barrel, nor for what model. A few months ago I had a Pantah barrel rebored and Nikasil coated by Langcourt of Weston Super Mare. They were very good. Is that the sort of thing you need?
  4. A set of ST3 barrels, not sure what coating is on the barrels.
  5. St3 is a nikasil type barrel, and as said langcourt is as good start but not the best, I think it is the only option in the uk though.
  6. strewth, how big are you going up to now! its a watercooled 2v you run isn't it?
  7. Blr engineering in London.
  8. Langcourt & BLR, cheers gents.
    Sev - That will take the motor out to 1098cc I think (98mm Pistons from a 996) but the motor is 3 valve, not for HP but for the torque :upyeah: should take it to high eighty low nineties. BBBBBBBBBBBBBBBBBAAAAAAARRRRRRRRRRRRRRRRRRRRPPPPP!!!!!
  9. I've used Langcourt a couple of times, quick turn around and quality was spot-on.
  10. If you get them Nikasil coated, be very careful if you should happen to fit chrome rings as well..........'Running in' is a must.
    AL
  11. Cheers Gents.
    Mr R quote Langcourt which is good enough for moi :wink:
