Bikes done 8k. Spanner appeared just below 6k. Bikes on a 04 plate. Is there an easy way to turn off the spanner icon? Or is it a Ducati dealer job? Bikes re commissioned by me at 4K. Belts, Desmo, iridium plugs, filters etc. Oil and filter at 6k. Belts will be swapped out again soon coming up 2 years since last done. Too tight to pay if there is some simple fix.
If you have an Android phone you can use Scan5MX with this cable and an ELM327 adaptor. Only cost is the hardware. As well as reseting the service warning Scan5MX will allow you to read and clear DTC, do various tests, reset the TPS and a host of other things.
