1200 Rear Brake Bleed
Discussion in 'Multistrada' started by Darrencrook, Jun 7, 2016.
  1. hello all. I have tried to bleed the brake as i had put new pads in after having the caliper in two halves to put new seals in. Now it wont bleed even with pumping the pedal as much as you can the fluid does not want to go down. Any joys with this.
  2. Presumably you are holding the caliper high up above the ABS unit while you are bleeding it. And presumably you have installed the extra bleed nipple on the ABS unit banjo bolt, and bled the air out as far as there. And tried a pressure or vacuum bleeding device. Yet you still can't get it to bleed - curious.
