Rear Brake Pads
Discussion in 'Technical Help' started by 999Paddy, Jul 11, 2020.
  1. Hi all,
    Bought the bike used--2003 999--and after a few years of riding it, it's time to change out the rear brake pads. Pulled out the old pads and they're 40mm wide. Looking up suppliers everything comes up about 50mm wide. I wonder if the previous owner put on a different caliper. It's a Brembo caliper. Any thoughts, suggestions?
  2. I dont know the answer but a pic may help.
  3. or fitted the wrong pads.
  4. The pads are correct for the caliper. Talked to a Duc shop owner. Apparently a different caliper was put on the bracket before I bought the bike. Wouldn't know until time to change out the pads. Is not like I breath all things Ducati and know every configuration and cross adaptability. Mystery solved.
  5. Introduce yourself properly in the newbies section too why don’t you?
