Does the rear brake only have one retaining alloy spring/clip under the pads? taken the pads out and only one fell out. Should there be two? Also my pads have big holes indented in the back of the pads. This normal? Cheers
Found the accessories diagram. It’s only one. Brakes are binding a touch. Any suggestions? Same pads as before when it wasn’t binding. Bled the system and there’s plenty of brake pressure. Are they just not coming back off enough? I cleaned the pistons and could push them back with my fingers so seemed ok. Too much brake fluid? It’s at max. Doesn’t appear to be over the limit. I hate mucking about with my brakes.
