On the single sided swingarm, the rear caliper bracket has a slight rotational movement. (Caliper is firmly bolted to the bracket) You can move it maybe 2-3mm. Is it designed to be like this? I just can’t remember noticing it before .
yes it works with the adjustability of the rear wheel back and forth for chain wear on the rotational adjustment
