Rear Lights
Discussion in 'Diavel' started by Matthew Warner, Dec 30, 2018.
  1. What's with the rear lights being kinda loose ?
    Not having a diavel before I'm curious as if this is normal or not ? They don't come off but move around a lot for something that I thought would be tight .
  2. They’re rubber mounted .. so normal for them to wobble a little. if too loose you can firm up with some rubber washers on the shouldered bolt
  3. yep, they are lose, it is the only way they can survive back there with all the vibration
