1260 Rear Sprocket Makes
Discussion in 'Multistrada' started by firecat0_0, Jan 11, 2026 at 6:07 PM.
  1. Hi,
    I am going to buy a 42 tooth rear sprocket for my 1260 multistrada and have a question. Would it be “better” to buy a esjot or afam steel one or a Supersprox tri metal - I am looking for reliability/longevity. Any insights would be appreciated. Cheers
  2. Renthal and JT sprockets are also work a look.
  3. renthal
    and you get a sticker
  4. Are they alloy?
  5. Steel will last longer than an aluminium alloy. Alloy ones are for weight saving :joy: - he laughs as it will make bugger all difference on a MultiStrada.
  6. I don’t want alloy, must admit I have used renthal for decades but only off road. I was unsure of the construction of the Supersprox tri metal, looks like a steel ring is riveted onto an alloy carrier hence my comment re reliability. I went 14 tooth on the front standard on the rear to try a gearing change and liked it hence looking at a 42 tooth rear.
