999 Rear Sprocket Nuts
Discussion in '749 / 999' started by Cream_Revenge, May 28, 2017.
  1. Are these reusable? Or a limit on the amount of times you can use? Should they have thread lock on?
    • Nuke Post Nuke Post x 1
  2. I just found one loose, was rubbing on paddock stand while spinning wheel to oil chain. Not sure if worked loose or I didn't tighten when putting it all back together, is possible I didn't torque up when wheel was loose as hard to torque when off bike then forget to tighten when putting back together. Put some white paint pen on them so I can see easy.
  3. May just thread lock them tomorrow.....
