Hi, does anybody have a size for the rear wheel nut on an 1198 please? It's rear pads time! Thanks, Ian
Notice mentioned a couple times above that the nuts 56mm, Are you guys sure its not 55MM?? I maybe wrong but hope not as ive just got the 55mm but not tried it yet 55mm + 30mm WHEEL NUT SOCKET TOOL FOR DUCATI 1098 1198 1199 MULTISTRADA DIAVEL | eBay
Seems to be 55mm.... A Google search agrees! Thanks again folks! (I'm not sure if the pads can be changed with the wheel on, I'm going to do a bit of cleaning as well while I'm at it!)
Sealey S34/55 walldrive� socket 55mm 3/4"sq drive - PVRDirect These will be much stronger than the bike-specific socket tools and they'll stand up to use with a 240v impact driver (which mine needs to get it undone). Some people get the chamfer milled off the the face of the socket so it sits down more securely on the thin wheel nut. Personally I've had no problem with mine the way it is and my impact driver is quite brutal. Don't forget a 3/4" drive adaptor if you've only got a 1/2" drive wrench.
