Noticed that some of the rubber well nuts for fixing the screen on my 748 are disintegrating badly. Can anyone recommend good alternatives to OEM as I can't stomach approximately £9 per screw and well nut but would like to keep it all looking standard. TIA!
I think you may want to double check with your OEM supplier but £9 could be the price of a complete kit (9 pcs).
Well, after double checking, these suppliers are offering them for a little less (6-7€ a pcs). You will need 9 pcs, so that’s a 70€-ish total. Not cheap, but still affordable and that means you can still find OEM fasteners out there. https://shop.oemducati.com/en/products/superbike/1996-1/748-1/cowling-85 https://www.stein-dinse.biz/product_info.php?products_id=1384
was hoping someone would come up with a demon supplier, I guess you have looked at this alternative? https://www.ebay.co.uk/itm/201499994097?hash=item2eea55e7f1:g:iH0AAOSwHSRhQeBC
should have added, i've used these plenty of times but vague memory of O.E.M. size being M2.5? I think I found clearance was adequate anyway even if slightly larger.
