748 Remove Brake Master Cylinder Location Pins
Discussion in '748 / 916 / 996 / 998' started by CarloL, Jul 16, 2018.
  1. Any advice to remove the brake master cylinder location pins on the handle bars , I am installing RCS19 and they do not have provision for the pins in the clamp
  2. It is what’s called a roll pin and if you twist and pull with a pair of mole grips or good pliers, it will just pull out. Retain the roll pin for when you want to refit the original master cylinder. Andy
