Hi all i am having trouble removing front breaks to change pads and removing front wheel, just have a standard front paddack stand, any help,would be great.:smile:
Undo the four caliper retaining bolts then pull of calipers. Slacken the axle end nut then the pinch bolts. Support on paddock stand and take of axle end bolt. Twat through the axle. Wheel off.
for some reason dose not seem enough room to remove calipers from dics as the front wheel is in the way ?
You're right...It's a tight squeeze but they do come off, just be careful not to score the pads on the edge of the disc as you ease the caliper around.
Twist the caliper against the disc to force the pads back.........then it will curl off the disc quite easily. AL
