Hi all I have a Multistrada 1100 reg 2008, 8500 miles It will start from cold fine. If I leave it going for a few minutes and then turn it off when I try to start it shortly afterwards it will not start easily unless I give it a little bit of throttle and even then it can be difficult to get going It has only started being a problem in the last few months after a service Any thoughts ?
you need to know if its sparking during cranking. i had a very similar fault with mine which eventually was traced to a faulty starter motor. crazy but true
