Ceepeedee ride height adjuster/lowering link. All nuts and rod ends included Billet aluminium for 848 EVO 848 1098 and 1198 Never used, never mounted - condition as new. £50 inc P and P
Not this year El T (but perhaps next year) - I never used it because I had the bike lowered by Kais. I just thought I would declutter and get a few bob before we move house.
How did they lower it without an adjustable ride height bar? Just turn the eccentric round? Fwiw and its not a lot of money, if you are keeping the bike I'd be tempted to put it on there at the same height at the tie rode you have now. At least if you adjust the chain you can keep same height.
Jeez...how much would that cost v £50 bar and drop the forks a little Funny enough I've ramped mine up today as I adj the chain but have no ride highet tool and count be bothered to measure it so we'll see how it hoes at cadwell
Have sent the OP a PM. For others on this thread who have one of these, how much of a job is it to fit? Do I need to have a means of holding the bike up off the suspension to fit this? I'm hoping it's a straight swap for the non-adjustable rod that's on as standard and I can just undo it and replace with this one. Andy
Shorter spring and adjustments to the fork. More expensive but the bike handles really well. You have made me think I should keep it now but I can't fit it myself.
Ar right, didnt know if you change the spring for a shorter one its reduces the eye to eye size. Every day a school day
My old man has an Abba. I'll just ask him to hold the tail up while I fit it! Will be fine I'm sure, we'll manage between the two of us. I assume this is basically a copy of the Ducati one? I couldn't find this make online but it looks almost identical. Was just wanting to check that it adjusts the height upwards too and isn't just for lowering it, as I want to adjust both ways but I'm pretty sure it's what I'm after. Have sent another PM anyway. Andy
i'm assuming that this may well have been snapped up but if not then let me know. For anyone that has one already is it worthwhile? I've booked some time with Colin at 100pc suspension at a trackday in Aug but wondered if it's worth putting one on in advance to help find a good set up?
Yep agree, got one and never used it but now have it on and raised rear a bit (after removing shock preload) as she is sweet. Note of caution- The ebay copies often have pants rod ends, mine lasted about 1200 miles and then had serious play (no winter use). I now have heavy duty race spec versions which are great. The Ducati ends are expensive (like £80)
