Right Hand Indicater Not Work And Data Tool Sysystem 3
Discussion in 'Technical Help' started by Muny, Sep 9, 2015.
  1. :):):)Hi
    Firstly went out on the 999s thi evening all good until the right indicater stopped working. Bulb I though but no put left one in did not work any thoughts to what it might be fuse may be where are they, also I have data tool system 3 on the bike that does work any ideas please.
    Cheers
    Andy
  2. If you have swapped a known to be working bulb and it's still not working the next step would be to check you have power at the connector which is located on a small bracket on the frame tube about 6" below the middle of the seat.
    With the ignition switch on: Using a multimeter or test lamp you should see power permanently on one of the wires for the rear light. Another wire should go live when brakes are operated. This leaves the indicator wires which should go on/off, if that all checks out o.k I would suspect the lamp holder live and earth connections
    #2 CRYSTALJOHN, Sep 9, 2015
