Anyone fitted these? Pics if possible please and how matt is the finish? I was going to fit the normal round ones but they are too shiny and dont look quite right - cant afford the MotoCorse titanium ones right now :wink: Universal Fluid Tanks by Rizoma Bikes Accessories -
They do look good and look like they have a satin finish which i like to,but would like to see one close up first. brian.
:smile: Might give Moore Speed Racing a call tomorrow, if they have any in stock I may pop down on Saturday, although I may pop down anyway
Those are pretty cool, I have the Rizoma standard fluid tanks in black and they are good aside from the inspection window is pretty minimal, you won't check like you can easily with a regular tank. Also, the tube exits from the side which is fine but not as neat as the pipe exiting from the base as these "next" models seem to. I won't change mine but if I was choosing now, I'd wait for these. Sent from my iPad using Tapatalk HD
Has anyone got these yet, were they easy to fit? has anyone fit them on a multistrada, is the black a satin finish.... what sizes did you get? ......and a million other questions:biggrin:
I am using the next 125 red for rear brake res on my Diavel will post pics when complete also doing gas cap and frame plugs
i have to black standard ones to put on my HP. got them on my custom busa as well. just make things look a little neater imo. yeah the inspection window is a little crap tho.
what do you mean you have them? on yer bike or for sale? if you have em fitted, to what bike, also i'm worried about Squishy
after much surfin, ct 115 for the rear, ct 125 & 127 for clutch and brake. This is just thru research and not by fitting as i only have my bike on order. will be fitting asap but the only delivery date i have is "march" so if yr prepared to wait i will post details
were they an easy fit? did you get brackets or do they fit straight on? i haven't got my bike yet so can't check, i wish it was here, my patience is a limited resource
I already had some rizoma brackets - you need these to make it look right they are easy to fit if you have the brackets
I would echo the necessity of the Rizoma brackets, the standard Ducati brackets are pretty lightweight and I found the heavier Rizoma tanks meant these did not provide the suppor required. The Rizoma brackets also look a lot better and are easier to set up as they are adjustable.
Here is the Next 125 used in place of rear res. on a Diavel Have to say these are nice very nice lol the 451 mount has many endless positons
