Rose Joint For An Ohlins Damper
Discussion in 'Technical Help' started by idrinkbeer, Jan 4, 2016.
  1. does anyone know if and where I can buy a rose joint for my ohlins damper? its an 8mm female right hand thread and the eye has a 6mm internal diameter.
  2. I will ring mtc and harris.....all the 8mm end joints seem to have an 8mm dia end ..........im after 6mm
    oh and thanks peter.
  3. Bought an 8x8 mm and will sleeve the eye to 6mm. When I removed the standard rose joint it had considerable wear and looking at the new one I would say 6mm is small for the job and 8mm looks more up to the job.
