I went out yesterday, and after stopping for a while then filling up at a shell garage, the bike was really rough running and didnt really want to rev much past 8000rpm, it would but was lumpy, really didnt sound happy, stopped again then on the way home it was fine revved clean and was smooth again? Anyone seen this before any ideas what could have caused it?
Thanks, I will keep an eye on it see how it goes next ride, it was lumpy felt lijelike it wasnt firing right, is there a fix for the front coil, to make more waterproof, if that was the problem.
Later versions of the coil are less susceptible, best to check the cleanliness and location of the connector which on early models is right on the spray line off the front wheel. Later ones have a flying lead and plug should be located away from that area, sometimes however the flying lead can get pinched by the fairing and shorts against the frame.
Later versions will retrofit with no problems or modification necessary and can be found on Ebay fairly cheaply.
Good to know, I will see next time its damp if it runs fine until it gets damp I wil pick up a later coil as thats more than likely the problem. Thanks
Hi how do you tell an older spec to a newer spec? Is it just the lengh of the fly lead? How long is the later one
Wouldn’t say so. The old connection allows ingress of water into the coil stick and usually shows up as a short. You can try sealing it up, if it works then you’ve saved... nothing to lose
Yeh I guess as the bike runs fine now, so if I seal it hopefully it wont get any more water/damp in it, and with the way the weathers going it will be easy to test
They tend to fail rather than perform intermittently, It's worth replacing with the later sealed version anyway but I doubt it's the issue here.
