S2r Exhaust gaskets
Discussion in 'Ducati General Discussion' started by salbalboa, Sep 1, 2012.
  1. Has any one ever managed to get the exhaust pipes to seal fully using the original gaskets?
    I have just fit new gaskets and the seal isn't perfect but alot better than it was. I might have to go down the route of high temp gasket sealant.
    Any one have any recommendations for sealing the joining pipes?
  2. I use Holts fire gum
  3. I managed to salvage and reuse the ones that joint the headers to the cat with no leaks, but the cat removal pipe to the link pipe for the cans leaked. I used clear bathroom silicone sealant and it worked perfectly. I also used it on my Superlight with no problems too. The problem with most exhaust sealant pastes is that they are not flexible and break up after a while. Silicone sealant flexes.
  4. I didnt think the silicone sealant would handle the heat from the exhaust.
  5. Silicone will withstand higher temperatures than the exhaust will generate
  6. NB: Do NOT use any silicone based sealant if your bike has Lamda/oxygen sensors, it buggers them. :wink:
