Hi all, I have been offered a 2006 Monster S4r that has done 9k miles, it has been off the road for a while but has just had a service including belts and other bits and pieces and an MOT and runs well. It has one problem the fuel tank is badly corroded inside to the point where I believe it has some pin holes in it as the white stripe across it has lifted!! My question is can fuel tanks from other models fit the S4r or is it only the ones from that model, as you can imagine S4r tanks are rare. If anyone knows where is one and can point me in the right direction it would be appreciated. Thanks.
no, you are correct - even the lowly 620* has the same tank, I just checked:- 586:1:037:2AA is red for example, 2AC is yellow etc *ditto for the M1000 All above are from 2004, plus year 2006 S4R also has the above Part number. https://issuu.com/ducatiomaha/docs/m620_ie_usa_04_ed_00?e=1222863/10927327 EDIT looks like later models (e.g. 2007 S4R) possibly not as straightforward as lists a different part number.
Here's one on ebay. https://www.ebay.co.uk/itm/26527520...ntrq:efeeeb2b17b0ab8585a35a88fffca7c4|iid:1 Add £150ish for it to be resprayed at your local body shop, factor £25 for decals from Image Works http://www.bike-stickers.com/homepage.htm
