Hi all, persuaded the wife to get an 800 Scrambler, result..... Am after a paddock stand to keep it more out of the way in the garage as space is a little tight, have any of you guys got any suggestions ? Cheers Mark
A cheap one and put a steel bar through the axle or get the R&G crash bobbins with paddock stand lift
If you can afford it get a vertical lift - gets all wheels off the ground - makes it easy to wheel about and push into a corner. I have the ConStand version - OK for the scrambler... but Chinese Quality.... OK for the light weight.... There are other makes
The rear swing arm is the same dimension as a 749/999 so the stand for that bike fits perfectly. That’s what I use. The Evotech rear bobbins are a through axle design and will let you use a hook style paddock stand.
