Scrambler Fuel Tank Removal???
Discussion in 'Technical Help' started by Wallock, Nov 4, 2025 at 4:28 PM.
  1. I Couldn't find anything on this forum so just info on what i did when taking off the Scrambler tank,
    Problem is the hoses on the fuel pump you need to crush a little the lock ring around the connector a little then pull out the pipe, there are two of these pipes and first remove the two breathers on the front so you can lift the tank, anyway don't expect to crush and pull the hoses, more chance to damage the connector then you need to buy a pump of find a way to repair the connector, there is one guy on youtube that did a repair with plastic ties. Me I did not want to force the connector so I used a Dremel disc to cut off the hose clips, then pulled the hoses of the male connectors, then with the tank on the ground I easily crushed the plastic lock ring and pulled out the connectors from the pump, then refitted the male connectors to the hoses with a new hose clips.
